i have a r33 gtst s1 and not long ago the electric window stopped working, i have tryed to get it working again but doesnt seem to go up...grrr
so because i have no money i just want the window up and just leave it like that......does anyone know how to manually put the window up ???
thanks
https://www.sau.com.au/forums/topic/291360-power-window-stuck-electric-window/
i think it may have been covered by archaeic bloke, and by the way good effort mate!!!
anyways just wanted to add my experience. I had a 1990 r32 gtst once, and the drivers sinde window started working intermittently and sometimes not at all. However, when it was not working it would make a 'click' as you press the button but nothing would happen.
Anyway, i had to take off the drivers side door trim (not hard) and then locate the (what i think is) amp. Its a small black box tucked away amongst the door metal. Since i then needed to get into this box to look at it, i had to cut it open at one end with a stanley knife. you can then pull the circuit board out. Upon looking at the board i could clearly see that some connections had come apart. SO it was a simple matter of re-soldering carefully and then putting it back together.....and it all worked perfectly again!!!
So...if you have the 'click' happening but no upy/downy action then the answer may well be the circuit board in this black box.
goodluck!
  • 6 months later...
if you hear NO clicking and NO whirring (my situation) then you're not getting power to the system.
that's whats happening in my 34, i want to get it fixed but wasn't sure what the problem is, money is hell tight, last night was pulled over and got a defect warning about them, im going to go out and look at fuse shortly, my side mirrors are working ( is that a different motor altogether or does it use the same one?)
i've noticed this happening with a lot of 33's but have not noticed any 34's, to PM them and ask.
  • 10 years later...
Thanks for the awesome input guys! However, my drivers window goes up and down like it should. My passenger window goes down just fine but will not go up using either switch. If I hook power up to the motor then it will go up AND down just fine. Any ideas?
Edited by OrangeDreamR33GTS
I hear the click for the drivers window in the window amp but not the passenger.
Same thing, just in the opposite direction, no? The motor will go in one direction when you give it power one way, the other direction when you give it power the other way. If it will go one way and not the other, it tends to suggest that the switch that controls the connection of those + & - wires to the motor is up the shit, no?
Generally (or at least usually) with these things, you need both switches (driver's and passenger's) for the passenger's window to work, because they are both in the circuit. When one is giving trouble, the other one can't make the window work.
Makes sense, I’ll try to clean the switch contact or just order a new switch.
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
