that was brutal haha dont think ill ever recover from that insult..
just stating a fact, you f**king like it dont read it u fag
heres an idea tho how bout u find a few friends and get a life so you dont have to be stirring up arguments on the net and shit.
Buy yourself a Hyundai Getz and stop driving your Skyline. Obviously your intellectual is pretty much the same as a donkey.
Please let us know how much fine you get when you take your car to the pit and they find out that you've got a screamer
and a de-cat pipe. :D
you cockeyedf**k already been ova pits. no fine
Im targeted being a RED p plater with a skyline unfortunately not the best of combinations
You will increase your chances of getting picked up with a screamer on there.
Chest thumping won't change that...
Lay, lady, lay, lay across my big brass bed
Whatever colors you have in your mind
I'll show them to you and you'll see them shine
Stay, lady, stay, stay with your man awhile
Until the break of day, let me see you make him smile
His clothes are dirty but his hands are clean
And you're the best thing that he's ever seen
Why wait any longer for the world to begin
You can have your cake and eat it too
Why wait any longer for the one you love
When he's standing in front of you
Stay, lady, stay, stay while the night is still ahead
I long to see you in the morning light
I long to reach for you in the night
Enough of this behaviour please.
Two warnings have been added to your account for the personal attacks.
Guest
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
