i think anyone who doesnt own a rs four s should mind their own business as half of this post is a discussion about the diff between a s and a rsfour .
heh real nice.
i fail to see how a boost issue MUST be specific to it being a manual. It could be, but surely we who own (or have owned, as in my case) an s2 RS4(V) can at least offer to help.
The boost solenoid is not complicated at all. Its just bleeding off pressure in order to lift the boost pressure by 2psi after 4500rpm. I'm not sure if this is how it works in the manual versions, but this is definitely what the solenoid does in function.
The vacuum lines just plug into different points on your intake, and also the wastegate actuator. The wastegate actuator then just measures the amount of pressure in the vacuum line. It will open the wastegate when pressure reaches 5psi, and will close it when its below that. Bleeding some pressure off as the solenoid does, will cause the wastegate to see LESS pressure, and thus stay closed a bit longer. If you bleed too much pressure off, by bypassing the solenoid and using too wide a hose, the wastegate actuator may never see 5psi and will stay closed, resulting in "unlimited" boost as mentioned in an earlier post. This is bad.
When the wastegate is closed, the boost pressure keeps building up. When its open, it stops the boost pressure from continuing to build up (ie. because the air is now escaping), and the boost pressure may even fall a little (as it will with a stock engine).
A common problem with these cars is that the wastegate sometimes can get either stuck open, or the spring may weaken and it will creep open rather than staying closed right up to 5psi. In both cases, it will not build boost or may build boost slowly or just slower than it should.
Hope this helps.
  • 1 year later...
After a year of searching this problem still not totally fixed, after fuel pump swap, mechanic changing all relevant sensors from our cars R34 to c34 then adding NISMO fuel pressure reg, running on dyno (mixtures are good), fault is much better. Car is detonating occasionally causing the ECU to put the car into the knock limp mode, this limp mode does not bring up an engine check light. Has anyone else had issues like this? I am still trying to find root cause, not just work around yet. Thanks also to those who posted!
  • 8 years later...
  • 1 month later...
Hey guys,
stagea - s2 rb25det
just done head gasket and timing kit etc
car has high flow turbo, fmic, bleed valve and exhaust and nistuned
Car back up and running fine but NO BOOST at all - as in it drives n/a fine boost gauge comes up to the 0 but not even 1psi of boost...
ideas?
How fast does it go? Is it boosting but the gauge is dead?
If really no boost you have dead turbo, incorrectly plumbed bleed valve, stuck or maladjusted waste gate or (most likely) massive leak.
If you can't find the leak by following the path around to look for a missing clamp etc the best way is to pull the turbo outlet pipe off and make up a plug with a tyre valve in the middle. If it won't hold say 20 psi you should easily be able to tell where the air is escaping.
Thanks for the reply. Should not be a dead turbocharger. It was perfect prior to me doing the head gasket etc.
i removed the wastegate circlip and operated by hand it opens and closes fine.
removed the intake pipe and spun the compressor wheel by hand - spins freely no issues.
ill make a boost leak tester and check for leaks shortly - a big leak would make the car run rough yes?? Runs perfect doesn’t drop idle etc just no spool.
  • 3 years later...
Hey mate, having similar issues to you.. While in this limp mode you were still able to freely rev it up (past 3-4k) as if it wasnt in a "limp home" mode?
The car ran fine, boost was less. I changed injectors with new OEM injectors and car is fine. I had injectors cleaned and flow tested. There was large differences in flow, both at low flow and high flow which I suspect caused detonation and lower boost 'limp' mode. The car is a factory 2000 RS4s. This is my experience and what worked for me (fixed issue).
Do a proper boost leak check man. That's pretty much exactly what happens when a coupler has popped off. Also solid chance it's crusty old ( or new ) coils
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
