Help R32 Misfire I Carnt Fix It Help!
Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
