S13 Silvia, Sr20 Non Turbo, Manual, Black, Drift Teks, S15 Brakes, Lsd, Sunroof
$4700 Firm
I recently acquired this car as part of a trade for my Aristo.
I MAY consider a trade with cash your way for a NEAT, STOCKISH S14/14A/180SX/R33 Turbo MANUAL with genuine low K's and no issues, but prefer a cash sale.
MAKE SURE YOU INCLUDE DETAILS/PHOTOS and BALLPARK PRICE if you want me to look at trades. If it's a good car and a good deal I'm interested...hell, if it's a well worn shoe and you can convince me it's worth what you want for it....I'm interested. If you can't be bothered saying anymore than "are you interested in ____?" then no thank you...I'm not
- S13, SR20 N/A...Factory black/5 Speed/Sunroof (no leaks!)
- Shimmed VLSD fitted
- Digital climate control (not sure if A/C needs gassing, but isn't cold)
- 17x8/17x9 Drift Teks (+34 I think) NEAR NEW WITH PERFECT TYRES
- Upgraded s15 4 pot brakes in the front
- Jasma approved extractors 4-2-1 with full cat back exhaust
- KYB damper adjustable struts
- 204xxx but the engine goes and sounds great. Any test welcome
- Crystal clear front indicators
- Nearly three months rego
Recently went through regency for non-standard steering wheel with no problems. Looks like it has had a minor front end bingle before, the gaurds and bonnet have been resprayed and look OK but not fantastic. Drives straight and true with no wobbles though, and engine and box are very healthy. Great cheap reliable car.
Check out the clickable thumbnails below for a closer look.
I may replace the brakes and wheels with standard items if someone wishes to purchase without these for a reduced amount, but I can't guarantee when I will have time to do this as I need some stock rims first.
Call/SMS 0409 069 251 or contact me via the ad or PM
Cheers,
Dre
mate that looks pretty f*kin smick!
i currently have a red KE70 corolla, 5 spd manual, twin carbies, racing bucket seats, $400 CD player, new speakers, bonnet scoop, spotties, racing steering wheel............. haha looking at about $2k for it plus money your way obviously!!!! Great drift project, first car or cheap daily!!!
http://www.skylinesaustralia.com/forums/po...85-P1060675.JPG
http://www.skylinesaustralia.com/forums/po...86-P1060677.JPG
very interested in your car and its a good price!
where about its adelaide are you?
im down south....
cheers ROLLINON :(
im down south....
cheers ROLLINON :(
Thanks mate, but not what I'm looking for
I'm happy to throw it in for some extra cash...and you can put it on if you like? I have had a fair bit of interest in this though and a couple of potential buyers so the price is firm. Any day during the week after 6:30 is fine, or tonight even if you want. Located in Elizabeth Vale.
Cheers,
Dre
Edited by VLT025
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
