A lot of people blab on about how their gtst are 'stock'
yet they have 3inch exhuast. Really is this stock?
Can you compare a pure stock vs a stock + 3inch exhuast?
the car with the exhuast will win provided both drivers equal skill level.
i have a pure stock nothing done expect a K & N filter. Yet i've bet many other stocks with 3inch exhuast. Shit driver? probably.
Any way my MAIN quesiton is, has anyone here who are PURE STOCK
boosted their car with bleed valve. YES pure stock NO exhuast but boosted say 9-10psi?
ANYONE?
https://www.sau.com.au/forums/topic/29151-what-is-stock-gtst/
Hi mupkant, perhaps the reason you are not getting much response is because what you are suggesting (boost up & no exhaust upgrade) is pretty silly. The standard exhaust on a turbo car is always the weakest link, improving the other links won't help. ie; you are already choking the turbo with the standard exhaust, so turning the boost up is pretty much a waste of time.
Plus, in my opinion, you are risking ceramic turbine failure earlier than if you upgraded the exhaust. This is because strangling the turbine does not allow the heat to escape and heat will kill the ceramic just as fast as excessive boost will.
Maybe that answered your question, in a round about way.
hehe yeh my car was completely stock when I got it. As in factory stock. The exhaust even had the date & month of the car's manufacturer stamped on it. No air pods, boost controllers. Took 11months for the importer to find a good condition factory stock 32. Only thing aftermarket was a Addzest aftermarket headunit.
Anyway i did what Sydneykid was talking about - stock car with more boost. Sure it gave it more power but you could definately feel the exhaust choking everything. Car now has 14psi boost, 3" 5Zigen dump-pipe back exhaust & remapped ecu. Funnily enough its a lot easier to drive because the power comes on sooner due to the exhaust. (I have dyno graphs of what each mod did)
Anyway yes, I have talked to lots of ppl who also tell me "yeh my car was stock too, all it had was 3" exhaust, pod....".
Yeah, mine is exactly what you described, dead stock except for bleed valve. (yeah, I know, that makes me an idiot :D )
It runs about 9-10psi.
For me exhaust note is a concern, the stocker is nice and quiet, its a daily driver and I hate droning exhaust.
Also, to me, I reckon a stock skyline is plenty fast enough for a road car, I'd rather learn how to make the most from a slow car, than to drive a faster car poorly...
Only other "performance" mods are 18" wheels and a tighter diff. Which makes mone pretty much the slowest GTST going around :)
my car only has a a 3" front pipe and dual cat back sys and im not surprised that stock as a rock lines will probably beat me....though no one has yet:D:D i find that with the exhaust u loose the kick when the boost hits at 2.5k but when it hits the 5k mark when full boost is on then its a different story:D
are u planin to run 9-10psi mupkant?? apparently u can get about 9psi by just gettin a full exhaust system??
mupkant,
No problems doing the bleed valve first. The exahust is always a good thing but, if you got no $ then the $90 for a bleeder is cheap and gets rid of the 'two step' boost of the factory controller. You can always keep the boost down to 10psi to save the ceramic turbine.
It works. so go do it.
mate, second thing I did after my bleed valve was the exhaust and I tell u what. Its quiet as anything. No in cabin drone at all and its even fairly quite at high rpms.
U just have to make sure you get a well designed one. Thats why I got a jap brand Jasma approved one. (5Zigen) The damn thing is so quiet i'm thinking of getting rid of one of the mufflers!
Mine is completely stock besides the K&N panel filter, turbo timer, and 2 stage boost controller. I bought it with the controller & timer on it. I have kept up with 32s only having like a cat back system running pretty much equivalent boost & same with 33s, but i have been hosed by a few running decent exhausts & being well tuned. It is running around 11psi. I think the previous owner should have focused on the exhaust first. Early next year i am getting a custom 3" turbo back zorst, along with heaps more goodies....
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
