Got a question ??
Ive removed the stock steering wheel with airbag and fitted an aftermarket steering wheel.
Theres a clip with 4 wires that attaches to the stock airbag and thats for the horn and airbag i take it.
Does anyone know which of the 4 wires obviously 2 are for the horn two are for the airbag but before i go cutting the wires id prefer to only have to cut the two that are for the horn and attach them to the aftermarket horn attachment.
hopefully that makes sence and someone can help ...
Thanks in advance
couldnt you use the continuity setting on a multimeter to check the wires from the horn relay to the wheels button? Most probes from the multimeters would reach that distance.
R33 GTST '96 mine where in two connectors....
one connector is for the horn, the other is for the abs.
what boss did you get? hkb has a female version of the horn connector on it, makes it easy.
