Looking for some fresh ideas.
My brothers R 32 GTR keeps stopping after running for about 3 to 5 minutes.
It just shuts down as if it is out of fuel, then you have to pull over and re start it.
So far we have tried many thing including the following.
- drained and replaced fuel.
- replaced the fuel pump.
- installed the earth bypass on the fuel pump.
- replaced the fuel filter.
- tryed driving it with the fuel cap off.
- replaced the fuel pump relay.
- swapped the ECU.
- spark plugs replaced.
All with no change what so ever, If any one has any ideas of what else we can try or if wore comes to worse , where to take it in Adelaide for repair, we are all ears.
Cheers Trev
https://www.sau.com.au/forums/topic/291535-gtr-keeps-stopping/
Have you cleaned the fuel tank? Once heard of a similar problem (in a Patrol) - turned out to be a piece of plastic that would get sucked onto the fuel pump. As soon as the engine was stopped, the plastic floated away.
What I think is most likely: Try a different fuel pressure regulator, injectors might be clogged and need cleaning, solder gone bad on an AFM (check DIY section for guide how to fix a AFM)
Long shot: faulty O2 sensor (unplug them both so ECU runs in open loop permanently), I only say this because it seems the car is running fine in open loop while warming up, and when it goes to closed loop it starves itself of fuel and stops.
Check the SA subforum for a sticky with trusted workshops, if you live in the northern suburbs send me a PM i'll give you the details of my mechanic who specializes in GTRs (r32 in particular)
ignition module/power transistor. most common sympton people experience is a missfire however when they get real bad they will intermittetly cut all power to the ignition until it has cooled (generally).
is it difficult to re-start?
thanks guys
The fuel tank was completly cleaned out.
When it stops you need to turn the ignition all the way off, after about 2 seconds you can hear a faint relay clicking noise from around the ECU area. You then turn the ignition on and the fuel pump seems to run for an extended period ( as if it has not been started for a week ). Then you can restart it and drive it home using minimum throttle.
Last night it was started in the drive way and left idiling for 15 min ,it then started to splutter and barley keep running.
we can swap my ignition module over and eliminate that in the next couple of days.
cheers Trev
changed the ignitor last night as it was an easy swap but no change.
Contacted alarm installer and Alarm is only connected to starter motor and not ECU.
We will start looking at the rail pressure and regulator next as well as the AFM,s.
may also give unplugging the O2 sensors a go.
Cheers Trev
Edited by GTR Trev
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
