Loving this thing at the moment, just gotta fix the limmiter issue, hits the hard limmiter before the soft limmiter so dies for 5 seconds then power comes back.
Other than that so much fun, effing loud but i dont do laps through town in it.
  • 2 months later...
Still havnt got any vids, never seem to have days off the same time as my mates, or if we do were off 4wding.
Finally got around to recoating the pillars with some more CF wrap so their not white and shitty, looks so much better.
Edited by msports180
  • 1 month later...
Havnt done a great deal to this lately.
Got some proper Bride rails to replace the dodgy one's we made, have re-done the catch can, as in put one in instead of just a bare filter, replaced some blue silicone hoses with black to match the rest and mounted up a fire extinguisher as having its first track day the 27th of this month.
Still havnt fixed the limmiter issue, looks like a trip to the tuners before the track day to try and sort it :(
  • 3 weeks later...
Well never got the limiter issue sorted before the track day, so did a mix of sprints and drifting, was hard drifting trying to keep one eye on the tacho and one on the road, also hard trying to keep it off the damn limiter!
Had fun none the less till i broke the gearbox, stuck in 3rd :( more money. I'll rip it out this weekend and drop it off to a mate to check it out, hopefully its just a selector or something.
I am also very rusty haha!!
Pic is off the drive home, stuck in 3rd, not fun!!
  • 8 months later...
Well this has been back on the road after quite a rest waiting for the gbox to get done as the dude was busy as hell.
Chucked in a Nismo 2way whilst it was off the road, after driving with it for a while i really dont know why it took me so long to put one in, forgot how nice they are. Also tracked down a stock S2 lip spoiler with the brake light and did a few other little things ive been putting off.
Just waiting for a track day or motorkhana to use the damn thing.
Anyone know a good brand for a oil filter sandwich plate? The cheap remote oil filter mount is leaking on this again so i just want to put something good on it.
  • 3 weeks later...
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
