After countless attempts at getting my R33 S2 Gtst to make good power, I am finally there and happy.
It is making 360rwhp and drives like a dream. Prior to this it was making 305rwhp with similar mods. The real difference - the tune (tuner to be exact). Sometimes switching tuners makes all the difference....
https://www.sau.com.au/forums/topic/291551-back-from-tune/
Dont want to rain on your parade as this is a huge jump just on tune but was it done on the same dyno in same conditions as this might be a reason for some gain which is not really there?
https://www.sau.com.au/forums/topic/291551-back-from-tune/#findComment-4874979
I am sure that if the car drives in such a way that he has been excited by it, the numbers probably are reflected in driving experience :P
agreed there would be gains just not close to 20% gain... also worried about the placibo effect you know it must be quicker cause the dyno said so...
i am not trying to be rude i just prefer stats that are real in terms of this... example is my car is identical to my brothers as in we are 100% neck and neck every drag/race but he has 28hp more then me... this is not my skill but a different dyno different day.
https://www.sau.com.au/forums/topic/291551-back-from-tune/#findComment-4875509
your brother needs to lay off the pies.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/291551-back-from-tune/#findComment-4875523
some tuners are lazy, and just pull a big chuck off the stock timing and smooth out the A/F ratio, sometimes not even touching the Injection map, they just scale the Air Flow Meter which is purely lazy.
I've borrowed a datalogit and fixed parts of my map up, and added more timing after peak torque (using a combination of old dyno graphs).
https://www.sau.com.au/forums/topic/291551-back-from-tune/#findComment-4875620
yeah there is a certain tuner/workshop in Sydney who tunes just like this...it was a mates car so i re-tuned it properly and made heaps of gains in power and response as well as fuel economy...and i cannot tune for sh1t but know enough to get things looking reasonable. Made 450AWKW the next day at Autosalon and won him a trophy...yay :D
this workshop charges big $$ too...pretty piss poor.
https://www.sau.com.au/forums/topic/291551-back-from-tune/#findComment-4875801
    • There's more than one way to skin that cat, and most of the sump Maatouks have done will be GTR sumps. They are HUGE in GTR drag racing here.
    • Yeah...I always start at the shift solenoids, because there's only a few reasons these will spook into limp mode, and bad shift solenoids is one ~ the other can be the shift control module (if you have steering wheel shift buttons)...it's easier to eliminate the solenoids first.
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
