sellin my interior, putting in some limited edition bride cugas.
front seats are up for outright sale $2800.
rear seat/door trims/rear trims are on a changeover basis only.
the passenger and rear seats are in very good condition
i lent my car to my brother for a month while i was away, and i think the constant getting in n out on the bolster wore it down a little and gave it some wear.
but its nothing serious, can be easily covered/stitched by a interior shop for around $100-150 to prevent any damage.
pics to come monday evening!
located on the gold coast, can send interstate easily, will be heavily bubble wrapped if need to.
n qld - $120
nsw- $150
vic - $250
sa - $250
(metro areas)
https://www.sau.com.au/forums/topic/291558-r34-gtr-vspec-2-interior/
