Hi guys,
Just doing some cleaning in the bay and i had a poke around where the belts are at the front of the engine. To my horror i find
some of the belts are cracked and torn on the side!!!!...the car has done 65,000Km, surely nothing happens to belts this early??
The belts are original, the say NISSAN all over it. Any opinions to why? and its solutions?............oh and i havent been hearing any weird noises or anything when starting up cold/warm or driving slow/hard.
Some pics to explain my point:
post-51287-1255315882_thumb.jpg<< Torn belt + Cracking
post-51287-1255315916_thumb.jpg<< another showing tear.
Cheers!
https://www.sau.com.au/forums/topic/291615-this-cant-be-normal-can-it/
I'd expect the belts may begin to crack but the fraying suggests something is wrong, possibly needs an adjustment somewhere as it is causing undue pressure on one side of the belt, or else something is pretruding and cutting it as it runs past.
I'd expect belts to show wear anywhere over 60,000km and due to their age (2003) cracking is always a possibility too.
During my last routine service at approx 56k my mechanic replaced all my belts due to cracking which at that time I was quite surprised but reading this thread makes me feel much better :D
Could you give an approximate figure of how much it cost your for the belts?....lol never in mylife have i had a car long enough to change the belts. First time for me.
mines the 2002 model and also cracked inside....at one stage when it was very cold in Melb, it used to squeek on start-up, but as it heated up, the noise would go away (less than 10 secs)...
i guess i better change mine soon.....i think it's definitely the age of the belts in most cases that would lead to cracks....besides, our VQ engines are very hot...so that would add to the equation somehow....
my v35 has only done 49,000kms....
Mine were in need of replacing at 35,000kms. Given the age of the vehicle and the fact that in japan the belts do way more kms than the speedo indicates, the belt condition is understandable.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
