  • Replies 83
im in melb i can come pick it up also need the glove box front sway bar heater core unit inside the dash all the carpet boot trimming charcoal canister and air box and snorkel and drive window switch no 0403011187 thanks mate really need all these things
Hi, have you still got your tail lights?
Where can i pick them up?
Thanks DAnnie
so i have decided to wreck my r33 instead of fixing it after crashing it. everything for sale is in good condition unless stated otherwise. listed below is everything i can think of but if you need something not listed pm me or call on 0400119068. all interior parts are ready now (12/10) and will have things like motor and gearbox out by the end of the week. i will post pics up on request. feel free to make an offer but im not in a hurry to sell so dont bother low balling!! cheers, Shane
gcg turbo- sold pending payment
engine (inluding front facing plenum)-1300
gearbox-1500
front brake set up (rotors and callipers)-350
back brake set up-150
front subframe-250
steering rack-100
apexi coilovers (adjustable damper)-550
rear subframe + diff (shimmed)-500
front seats-200
rear seat-50
pedals-50
passenger door-120
drivers door (panel damaged, good for window and interior)-70
spare driver door (bought it to fix the car)-100
spoiler and boot-200
seat belts-100 the lot
s2 head lights. (2x left and 1x right)-250 each
fuel tank-50
tailshaft-100
heavy duty clutch and flywheel-100
brake master cylinder/booster-100
front 1/4 panels-120 each
side skirts (right side one slighty damaged)-50
white line swaybar-200
full exhausted system including front+dump pipe, high flow cat-500
big injectors-300
split fire coil pack-300
roll cage (half cage with side intrusion bars made by brown davis)-1000
17inch g-max rims (no tyres)-500
loom-100
tail lights-60
starter motor-40
defi water temp and oil temp gauge + defi control unit (missing oil temp sensor)-400
speedo cluster with 106k on the clock-150
would you have the round thin plate with a wire ribbon that sits behind the steering wheel that plugs into the airbag computer is about 2 or 3 mil thick and about 100 mil across is black with yellow info sticker on it if you have how much with postage to tassie thanks you can contact me on 0408802254 or pm on here your call
Ill take the seat belts if they aren't already gone. Id also like some interior trim (handbrake boot, gearstick boot, carmats...) you name your price
  • 2 months later...
hey mate
i am after a piping that goes from the ic piping to somwhere (i dont know) near the stock bov.....
here is what i am after
if you have it them pm me please
  • 3 weeks later...
Hey mate i know its an old post,
But just wondering if u hav any of these parts i need??
- Frount passenger side quater panel
- The inner Frount gard Lh side were the cooler piping
goes thro and were the head light bolts up
i need that whole section
- S2 LH side, headlight
- Radiator suport bar
- frount reo bar, infrount of cooler
Any help would be much appreciated
if u hav any of the above send us a msg on 0403 236 931
cheers troy..
  • 2 months later...
im after the Heater AirFlow Direction Mode Actuator (underneath the dash passanger side above centre heater box) & a Heater Temperature Mode Actuator (driverside on the heater box pedal lil black box)..
if u got both of the PM me plz with a price from them..
cheers,
Robbie
  • 3 weeks later...
