Wrecking R33 Gtst S2 1996
By robbo_rb180 · Posted
Could you run an air drier inline to help with trapping moisture? I have heard some of the stories with the rules and that but I did have a good conversation the other week about the changes and possibility of another event in the USA at a famous track. Waiting for the rules is a pain as I am trying to sort final bits of my car and want to know where I fit in. -
By drifter17a · Posted
Hi all my r34 has been off for over a year with occasional start. Today I noticed a lot of noise from engine bay when turning the wheel as if power steering has no fluid . Checked and loads of fluid had flowed out of the resorvoir. Has anything been blocked/ destroyed? Maybe fluid can’t get into pump and flowing out ? could it need bleeding by turning steering side to side? thoughts? -
so will this basically make the gearbox decent? because it takes imo so long to shift gears and even drop back. the response when you have it in manual mode is laot better but even the shift is like not instant will this change that?
also the 400R will probley hold its value more but dont forget there is a Nismo model 400R aswell.
