1989 R31 Silhouette Series 3
RB20DET w rb20 box (has been through Regency and registered with the new engine)
Has upgraded brakes, not sure what model, i assume R32.
Chassis 370000ks+
Engine 45000ks
Alloy rad
FMIC
Aftermarket Turbosmart? blow off valve, plumbed in properly, mad flutters
Battery relocated to boot
remapped RB20 ecu
Jaycar Boost Controller
RB25 turbo (very new!)
some sort of black stockies, rear tyres are worn
Cusco strut brace
CD player, front speakers with tweeters
Aftermarket Guages (volts, oil pressure, water temp, boost (psi), RPM)
Ill throw in some tie rod end spacers for that extra drift lock
Fairly sure it has a 3" turbo back exhuast.
Seriously, this car has character. Wind some more boost into this thing and it will be fun on the track, or keep it as your daily. Im selling this due to not selling my R34. Ill take $4200 with an extra 3 months rego for you. This is relatively cheap for a registered 31 Silhouette S3 with rb20. Price is not negotiable, paid this price not very long ago.
The car is currently draining batteries, i havent had the time to find the source of the problem, but im almost certain its the head unit. You can always disconnect the battery everytime you park it for that ultra ghetto flavour. Keeps thieves from running off with it too. Itll come with an extra battery.
pics:
https://www.sau.com.au/forums/topic/291634-r31-series-3-silhouette-w-rb20det/
Sent an email last night i am really keen to get it. if u can let me know where abouts u live nd number i can come over tonight after work or on weekend. depends wat suites us both better.
got a guy coming tomorrow night, ill post up here tomorrow night if car is sold or still available.
Dibs on this car if the sale falls through, if i come to look will have the cash with me. very keen.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
