Group Buy - R32 Ecu Remap - Re Customs
I have been speaking to RE Customs and have negotiated a dedicated day specifically for remapping R32 skyline ECU's.
The following will be offered in a package for R32 owners
1. ECU removal and modification performed to allow remapping.
This involves taking out your cars computer and soldering in a socket. this means you can have either your stock map fitted or the remap. it also means if you need your car retuned at a later date the new tune can be popped in the socket in 5 min.
2. Full Custom Dynotune.
The car will be put on the dyno and first a power run will be conducted to check your power and AFR's. this base run will help to detrmine exactly what is happing with your current state of tune.
The Car's ECU will then be plugged into tuning equipment that allows the fuel, timing and various maps to be changed. thus making the standard ECU perform the same function as a power FC or other aftermarket computer. the car will then be tuned for optimal safe power and the best AFR's obtainable. if you wish the rev limit and speed limits can be changed.
Once the tune has been completed a final dyno run will be conducted and you will get a before and after dyno graph showing you how much of an increase you have actually got.
The whole process will take over an hour and we need 8 cars to make it happen.
Ray has been nice enough to allow it to be done on a Saturday so any interested parties can attend.
the benifits will be a more powerful car with a standard looking computer.
any upgrades eg: turbo, injectors, AFM, fuelpump FMIC ect your car has, you will benifit from a remap.
The cost per car will be $300 if we can get 8 people. it will be a full day event and a good change to meet others.
normal price for the service would be $455 so its a huge saving and probably the cheapest tuning package available. As a bit of a bonus to SAU, $10 per car tuned will be donated to the site to keep our community going.
Where: RE Customs - Springvale VIC
When: To be announced depending on peoples availability
Group Buy end time: 12th November. earlier if we get 8 cars before then.
contact: me via PM or here below.
Thanks!
https://www.sau.com.au/forums/topic/291643-group-buy-r32-ecu-remap-re-customs/
Hi Kyle, this is a service I have negotiated in conjunction with Ray, and may be done on a semi regular basis depending on demand but only in a group format that is organised like this through SAU.
cheers!
Wow this seems like a really good opportunity for members and SAU as a website.
I can see you have good intentions but I fail to see how anybody could possibly do a proper tune in ~45minutes when bigger injectors and turbos are involved.
Hi Matt,
To try and keep costs down there will be an operator driving the car on the dyno and myself tuning the car. This reduces the time it takes to tune a car usually by almost half. because the tuned can concentrate and watch with great detail what is going on.
because the tune can be done in realtime once the baselines are done you can do the tune very quickly if the modifications are farily basic. (rb25 turbo on rb20) ect. If you have put a gt35, Z32 and GTR injectors they you you are right it will take possibly triple that.
as stated earlier it will take over an hour per car.
cheers!
Im in for this. Hopefully we can get 8 cars, been wanting to get a remap for a while and now that i got some extra money i was planning to do it soon. Got the minor mods (rb25 turbo,fmic,pod,std inj) so this will probably be a good option for me, either this or get it remapped at status tune which im thinking about doing as well
CEF11E tuned the old rb20 in my bmw taking it from ~130rwkw to 170rwkw running basic mods and stock turbo.. obviously very noticeable gains..!
Have moved onto rb26 now, but definately would recommend this service to anyone chasing power from their 20..
  • 3 weeks later...
due to lack of interest the group buy has been closed. thanks all!
How about starting or extending it to R33 GTST RB25det's? I feel that there are a few of us around who would definately be interested in this group buy then.....
Dazza
Guest
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
