I've done some ringing around of the big tuners in other states and asked them to do some research for me regarding whos the best in SA. Two of them both mentioned Brett at APE, from the website looks like they mainly do highpower XR6 turbos and the like. I'm waiting to hear back from Brett so I can discuss with him cost and how he goes about it but thought I'd ask for any opinions here.
If they are bad to avoid thread being closed due to VV please PM them to me. Cheers :D
I've only used APE (aka Graham West Workshops) to do work on one of my cars. I had the Stagea dynoed to map in my Jaycar IEBC & DFA. IMHO Brett West is an intelligent and easy to speak to person, who will talk technical to you if you want him to, and be frank about your expectations. He runs a very high duty-cycle on his dyno (i.e. it's in use nearly all day, every day) and he works with all kinds of management systems. His current ECU of choice is the Vipec - which appears to be a very capable unit (I may fit one to my Z if I can sell my MoTec M48).
He is professional, and competent - I know for a fact that you could do much worse (I have seen some very ordinary mapping and shoddy workmanship over the years - but thankfully not on my cars!)
What are you looking at doing?
rb25det rebuilt with forged pistons, gcg highflow, z32 afm, gtr injectors, rising rate regulator, nistune.
Going to get it tuned with stock afm (basic safe tune) to get through regency, then go the z32 and go all out, looking around 18-20psi and keeping the tune safe.
why only 18-20 "safe" tune you've built the engine spent the money go 25-30 psi SAFE tune safe only means 11.7 AFR even 12 with low knock can be considered safe but tuners would rather see 11.7
what make a tune unsafe is not enough fuel even a built engine will go bang with no fuel
I had my turbos on my GTR swapped over and my exhaust changed at Graham West (APE). The work was great i never had a single problem with the work performed. I also had a bunch of free work done by them too before the turbo swap (Its the reason i took it to them to do the swap). My brother in law has his S15 serviced there aswell and has been given great service.
I definately recommend them.
Edited by Cooper
I spoke to gcg and they said the turbo wont make any more power after 20psi with the standard internal gate. The tuners I've spoken to think 12-12.5 is safe if you watch the egts and knock.
Ah that explains it then :down:
Yep will just cook the air if I go to 25psi from what Ive heard, I think theres oil problems with the turbo atm though so Im looking into that before I start smashing boost out of it. Think the oil seal is leaking into the exhaust housing.
What would I look for, I mean its already going to be black as f**k, are there any obvious signs its leaking oil if I take the dump pipe off?
Edited by Rolls
Not sure, i would personaly take it to Bill at adelaide turbo services
Why is that? I've had lots of recommendations and just about every name has had someone PM me and tell me a horror story. I'm quite confused with who to go to.
Brett West at APE is the only person I would trust tuning my GTR in Adelaide, his attention to detail is brilliant and he is a great guy to work with. First one in SA to install and tune my Vipec V88 :)
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
