1997 200sx, purple, manual, sunroof, 52000km only with serive history, 17 inch wheels, brembo brake, apexi AX53B70 turbo, apexi GT intercooler, Apexi GT exhaust, HKS suspenion, poineer HiFi system (12 CD) and with speaker, window tinted, Apexi gaug (Oil temp, Bar meter, Oil pressure), Apexi 550 CC injector, and GTR GT racing fuel pump, Motec M48 Pro computer, sport seat with engineering paper and register with VIC rd already and much more pls ring for information, PS: all orginal parts in box
$32500
call: 0411330962
email: [email protected]
https://www.sau.com.au/forums/topic/29166-modified-200sx-for-sale/
$32500
call: 0411330962
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
