I need to know where to put the jacks stands on my R33, I have tried doing a search and found some info but no pics and I am not 100% sure where to put them and dont want to cause damage to the car. If any body has pictures or can point me in the right direction it would be much appreciated
https://www.sau.com.au/forums/topic/291670-jack-points/
are you planning on jacking up the whole car or just one side/end? the proper places are under the door sill just behind the front wheels and just in front of the rear wheels. there is usually 2 small notches in the sill. otherwise you can put them under parts of the suspension points or even the cross member under the engine.
https://www.sau.com.au/forums/topic/291670-jack-points/#findComment-4879143
Whatever you do, don't jack it in the centre, under the sump lol.
I haven't jacked my skyline yet, but on the VL, we always jacked it just under where the springs are for the front, but I can't remember the back...something makes me think the diff, but then again I'm thinking that would have had adverse effects just like using the sump.
https://www.sau.com.au/forums/topic/291670-jack-points/#findComment-4879202
vl's had a standard diff (no IRS) so you could jack them off the diff if you did it near the suspension mounts. but you can also jack the car (either skyline or vl) from the actual diff housing as they are rather solid, however it isn't the best as the car can still tip to one side so jacking or placing jack stands as close to the outside of the car is the most stable and safest way to do it.
https://www.sau.com.au/forums/topic/291670-jack-points/#findComment-4879244
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
