  newboost said:
This is one of those subjects that seem to go around and around. What I am trying to find out is how has one, what brand is it, how much did it cost, and was it really worth the money.
All that i need is the facts not wild claims.
i have a 6 boost lowmount maifold bolted up to my gt35/40
awesome designed manifold with the merge collector
cost me about $1,200 but expect atleast a 1 onth wait for it to be made
https://www.sau.com.au/forums/topic/291681-rb25det/#findComment-4876216
HKS cast low mount, one of the better flowing systems in tests, its cast so less likely to suffer from cracking, I was going an external gate, and pretty much everything stayed where it had to, didn't have to relocate anything, and I didn't have to wait 6 months.
https://www.sau.com.au/forums/topic/291681-rb25det/#findComment-4878940
wow u went to all that trouble buying a flash manifold yet u chop and shut the stock inlet? lol hmm
i wouldnt mind a nice low mount manifold either..but is it worth it? probably not.
https://www.sau.com.au/forums/topic/291681-rb25det/#findComment-4878968
^ I was thinking a similar thing.
Either way it is hard to quantify "was it worth" the money, without knowing the full setup.
eg: Is a manifold other than stock worth it on say a GT3071? No, money can be spent elsewhere.
Depending on your setup & application is the most important factor to gauge wether or not you need or do not need one.
https://www.sau.com.au/forums/topic/291681-rb25det/#findComment-4879096
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
