my experience: nexen n3000: unbelievable grip cold or hot... and only about $130each traction rated at AA and also temp is rated at AA i think
another is khumo ecsta very similar.... $130 each fitted as well
these prices were for 215/45/17's
obviously 18's will be more pricey
As has been stated Falken RT615's are like the KU36's and Federal 595's
They are designed to be a high performance road tyre, not a semi slick.
Falken have two semi slicks, the RT215 and the RS-V04 which both have a lot more grip.
  • Replies 114
The RT615 replaces the RT215 IIRC... both are an S compound "semi"
Not quite, the RT615 is really a good street tyre, the RT215 is a proper semi slick.
I know that Tempe Tyres still sell both, the RT 215 is a much softer compound with a lower tread wear rating and bigger tread blocks.
The RS-V04 is stickier again.
No, Ryan was right the first time. The RT615 supercedes the RT215.
The RT215s have a Treadwear of 180. The RT615s have a Treadwear of 200. It's not "much softer". And since the tyres have been discontinued for quite some time, the RT215s Tempe is selling will be old.
And also not road legal in Australia. I used to run a set, and it took me a few months to notice that they have no European nor US DOT markings on them.
They are also, to my knowledge, discontinued. Falken hasn't advertised them on their Japan nor US web sites for a few years.
Thankyou.
I know the RT215 was seen to be a better weekend tyre than the RT625 but I am guessing the RT615 was made to be the way it is for a reason that suits Falken and possibly the market they are aiming it at.
The tyres I currently have on my car read: 225/40 R18 on the front, and 255/35 R18 on the rear.
The KU36 has the front size perfectly, but only 245/40 R18, or 265/35 R18 for the rear.
Once again, excuse my noobishness, I have been doing some reading but it is difficult to find decent information as most of what google finds are short tidbits of information given out by companies trying to sell to you.
Is there only one size of tyre that fits each size of rim, or can tyres be stretched/compressed or rolled differently so you have different sidewall height etc?
Also, if tyres can be stretched etc, it can be assumed that the readings on the tyres may not be the best for my rim anyway. Finding the width is any enough, but how do you work out what kind of sidewall you want?
Thanks again.
Edit: I just measured with a ruler, they're 10.5 inches on the back (265) and 9.5 (240) on the front. I think I'm answering my own questions here. So would my best option be the 245/40 R18 on the front and 265/35 R18 on the back? Thanks.
I ran the KU36 on my Supra, 245/40 front and 275/35 R18 rear. The rear gaurds needed slight lipping to clear them on my 9.5" rims - can't remember the offset. I was prety happy with them even on the track - they were surprisingly good actually.
You can't beat the KU36 for bang for buck as a combination street/track tyre. I also have them on my Legnum daily driver and they're wearing well on it.
Nice infos here but on a side note anyone has any recommendation if you factor in noise? I'm looking at getting new tyres for the missus' beelte. Been reading on the RE001 and apparently they're not very good on wet (dont know how the driver drives though). I'm thinking of KU31 or the Esta KU31? But which would have the best compromise for noise/wear(>30000km)/grip(wet/dry)? Looking at 215/45/17.
I'm currently having RE050A on mine and love it. The bit that turns me off is the price tag. But if all else fail, I might have to op for it.
Hi There!
This is Shanilee!
Im new in this site!
I hope I can have more friends here!
I'd consider these as well as the KU36s. Don't bother with RT615s; they cost more and I don't know if they perform noticably better.
Thanks!
Have a nice day to all!
Good Luck!...
Car Sale Hub
Boston Used Cars
Edited by shanilee
RE001 is an incredible tyre in the wet... Who told you they weren't? I bought them for that purpose.
I'm not sure what market they were aimed at.
My last 3 sets of tyres were:
RT215 (245 width rear) -> FK452 (285 width rear) -> RT615 (275 width rear).
The RT615s are comparatively rubbish as a street tyre. I don't think that there's that much more outright grip out of them than the FK452s (I haven't driven them hard for long enough to compare overheating points) but I remember how loose the car felt when I went from the RT215 to the FK452s, despite the noticably wider footprint.
To be fair, it could have been a specific batch of bad tyres though. A mate of mine got RT615s about the same time I did, and he replaced them recently. He said his new set are noticably grippier. I'm still reluctant to replace these RT615s with another set, given my current experiences, though.
I'm considering just putting KU36's on the front of my car for the time being, is this a bad idea?
Main reason is the front right tyre is pretty much unroadworthy, I'm low on funds and I'm headed to Deca soon. I figure I may as well shred the old tyres up at DECA and replace them shortly after.
Is there any complications I might encounter having high performance road tyres on the front and average tyres on the rear?
Thanks.
Thanks.
oversteer
considering the rears will wear quicker anyway(most likely, based on most sports RWD car owners driving styles), it might work out okay. just do it IMO. better than having no turn in and having an accident due to bald front tyres.
oversteer
Cheers mate, might actually combat the understeer I suffer from already!
i got the ku31s on missus accord ..beautiful smooth & quiet tyre.. maybe a bit soft..but good
wouldnt bother with KU36's with just skidpan, NEED heat badly. the only other real bang for buck tyre i can think of is the Direzza Z1 Star Spec, but once again, really does better with heat (not as bad as the KU36 tho)
lip to lip, or bead seat to bead seat?
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
