its been done so much. My mate wants my spare rb25 parts to do it at the moment. Its alright but there is one problem where the oil galleries clog up easily. They line up fine but the drift r31 has gone through 2 engines because of this. I am thinking about doing a huge right up and attaching what is already in one of the sticky's about how to get N\A performance. Have a look at it because it covers a lot about he rb25\30 conversion. Your going to have to study what parts to use because i know r31 conrods can not go over 6500rpm or the will crack....
To be honest i just did a 2.7L bore and hone :banana: worked well with a full recondition.
https://www.sau.com.au/forums/topic/291725-rb2530de/#findComment-4876622
  N-DAWG said:
More torque but I think it lowers the compression slightly? I'm not entirely sure.
Definitely more torque as N-DAWG has said. However use the pistons out of the RB25 and it lifts the compression to 10:1.
For my RB30DE I used the R33 RB25 head and kept the VCT. (you can use the R32 RB25 non vct head if you like. Its easier but the intake ports are slightly smaller so "may" not perform quite as well)
My R32 only had a RB20DE so the difference in grunt with the RB30DE is substanial.
And this is all on std R33 RB25 ECU, std cams, RB20DE exhaust, RB20DET throttle body and RB25 injectors. RB20DE fuel pump.
Only non factory part used is custom front facing plenum and air cleaner
No go fast bits at all so if you want to put more dosh into it there plenty more to be had before a turbo is required.
Nigel
Edited by Nigel Nichols
https://www.sau.com.au/forums/topic/291725-rb2530de/#findComment-4876985
  • 2 months later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
