1995 White R33 GTST Series 1.5
Mileage: 117XXX kms
Contact: 0433 712 092
Asking Price: $14500 O.N.O
Mods:
- Greddy FMIC (uses factory piping)
- HKS 2540 turbo (240rwkw at 1.2Bar. However I drive at 0.8 bar all the time)
- Bosch Fuel Pump
- Malpasi Fuel Regulator
- Hi Flowed Factor Injectors (That's what the previous owner told me)
- Cooling Pro Alloy Radiator
- 9 Puk heavy duty clutch
- Apexi AVCR Electronic Boost Controller
- 3" RSR Exhaust from the Front Pipe
- Garage Saurus Chipped ECU from Japan (http://www.g-saurus.jp/01contents/01contents.html)
- 17" Work Meister S1 2 Piece Rims (white)
- Almost new 245/40/17 KU31 tyres all round. Used less than 1000kms
- R33 GTR rear Sway Bar (27mm)
- Oil Catch Can
- Front Strut Brace (unknown brand)
This car was a little rough when I got it from the previous owner. Changed all fluids when I got it. (brake / power steering / clutch / engine oil / spark plugs)
- Had a little rust in the radiator (So I flushed it and changed to an alloy one. Changed a couple of the radiator hoses as well)
- Rear Bar had some pretty bad key marks ( Bought a 2nd hand one which was in much better condition)
- A bit of oil was leaking from the rocker cover gaskets so I replaced them as well.
- Key / Lock Assembly on the Boot was broken. Replaced with a new one.
- Interior plastics were a little faded / scratched. Replaced with Series 2 Dash Facia.
On the whole this car is mechanically A1. Usual service performed every 5000kms. Only reason I'm selling is cause I'm after something else now.
Now for the pics!
Edited by bin
https://www.sau.com.au/forums/topic/291734-eoi-r33-gtst-series-15/
  • 3 weeks later...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
