Caliper/Dog-bone spacers, to mount the caliper further away from the hub that the factory position, where can I buy these dardies ?
I need some so I can ram my R33 brakes onto my A31 knuckles, and cant even find any luck via Google apart from those who make their own.
Anybody shed some light on this? Wanted urgently.
Edited by Nic_A31
https://www.sau.com.au/forums/topic/291739-caliper-spacers/
I doubt you'll find anything off the shelf and if it wasn't so urgent I could draw some up for you.
I'm modelling my current dogbones and will be using them as a basis to develop some for the stag (this is to use stock calipers with 324mm 33gtr rotors).
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4877376
33 calipers n rotors go straight onto a31 stub axles ..
Bubba i have some bones if you want to copy them :P
Edited by Dsturbd
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4877404
bubba another option is ebay...
they sell cheap billet spacers in teh US of assholes
i think they are advertised as S14 to 350z spacing or similar (which is the same 280->324mm)
im going to get some one day when my car gets on the road (after bart finally give me the parts i need *cough*)
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4878182
A31 stock rotors are same size as S13 SR20DET, the calipers fit onto those, but I want to use bigger rotors as well, definately dont fit 9yes Im doing a 5 stud conversion too). Couldnt see anything on eBay...got a link buddy?
Otherwise, Bubba, how much do you want to make me up a set of those for all 4 s?
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4878385
You telling me 33 gts-t calipers n rotors dont fit onto a31 stub axles ???
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4879330
Have to be careful as 350Z have a different offset I think, we discovered an issue when trying to find discs for the Stag.
33 gts-t or 32 GTR calipers to suit 324mm rotor .
Marbles go play with some bees
Already got some, cheers :) Although, if you can send me a photo of them that'd be cool (so I can see if they differ to what I already have).
Not sure dude, I just draw the stuff :)
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4879736
R33 GTST rotors are massive compared to the S13 / A31, so there's no way in hell you can fit the caliper on the rotors onto an S13 knuckle.
Word of advice , you have no idea what your doing so do all road users a favour and have some one who knows brakes do your work :D
These 2 set ups bolt straight onto s13 hubs .. remove old shitty single piston calipers n fit directly onto hub n stub axle
33 GTR .. 324mm rotor .. larger then 33 gts-t
Project MU .. 335mm rotor
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4881369
Mate the calipers fit onto the knuckle just fine, its fitting the calipers on with BIGGER ROTORS.
I cant fit the rotors on and the calipers which is why i need to space them further away from the centre?
Edited by Nic_A31
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4881654
A31 knuckles
5 stud hubs
R33 GTST Rotors
R33 GTST Calipers
Hence why I CAN mount the calipers if I were to use the A31/S13 rotors, but the caliper otherwise sits too close to the centre to use R33 rotors.
Do I need to take photo's / draw picture?
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4881845
A31 knuckles
5 stud hubs
R33 GTST Rotors
R33 GTST Calipers
YES draw me a picture .. NO dragons though
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4881970
That's pretty odd.. I've found that between the models, the difference for the bigger rotors is in the caliper.. therefore the 33gtst calipers should bolt onto the A31 knuckles in the right spot to use 33gtst rotors..
Are you sure you have 33gtst calipers and not 32gtst?
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4882003
34 series has different size bolt n hole on front but other then that they still fit up .. In process of doing 34 turbo brakes onto my 31 wagon with monster rb30e :whistling:
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4882051
Yeah 34's have the same size bolts on the front as my Stagea.
The reason I am developing new dogbones/brackets is the ones off my 32 don't fit onto the Stagea.. it clashes with part of the knuckle which I can only assume is a 4WD thing.. if I could be bothered I'd try them on my mates GTS4 and confirm that.
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4882064
Stagea thing , gts-4 has same calipers n rotors as gts-t :whistling:
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4882095
Yeah I know they are the same brake setup but are the knuckles the same rwd to awd?
32gtst brakes fit straight onto the Stag but if I try to use the adapter brackets, the bracket itself hits a big balljoint looking thing.
Being that Stageas are a piecemeal car, I highly doubt their knuckles/hubs are specific to the WGNC34. More likely they are 33gtr/gts4 hubs/knuckles.
My guess is that due to there being an axle through the centre of the hub, that the lower joint maybe sits lower than on the skyline.. if I had both in the air next to each other I could sus out exactly what the differences are.
https://www.sau.com.au/forums/topic/291739-caliper-spacers/#findComment-4882144
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
