Im thinking about not playing cars for a while.
1978 C210 skyline sedan.
Recent respray in galaxy blue.
L28
5 speed
P90a turbo head
Early emmissions free hitachi twin carbs.
Oversize pistons
Big lumpy cam
Custom harmonic balancer
New 2.5 in exhaust with extractors.
Car is 99% RUST FREE (some very light surface rust in engine bay)
Now, the engine is making a sort of ticking or light knocking sound before its warmed up.
It has just had new rear wheel cylinders fitted.
$4000 or
$3500 with ADM tail lights
Jarryd
(07)54783158
[email protected]
QLD, Sunshine Coast
Edited by D-limo
https://www.sau.com.au/forums/topic/291752-l28-c210-fs/
  • Replies 40
Sorry guys, I'm putting the sale on hold till I sort a few things out.
Just checked the head and defferz reads 'p90a'
The main reason I put it up for sale is I yearn for another DR30 (I've had 4 of the things).
'If' the right offer came along I might be persueded. Or swaps for a dr30 :)
https://www.sau.com.au/forums/topic/291752-l28-c210-fs/#findComment-4880005
some kids smashed my hotplates when i first got it it was out the front for only 1 night n they broke em, the body n stuff on mine is pretty average and has quite alot of rust so after a almost perfect body for it :ninja: will get some pics up the next few days :)
do they still have arms or did you RIP THEM OFF?!?
https://www.sau.com.au/forums/topic/291752-l28-c210-fs/#findComment-4888454
  • 4 weeks later...
I'd like to move some parts out your garage, THEM TAIL LIGHTS. Can someone buy this car and sell me the tail lights PLEEEEEEASE.
it took me a year and a half to find matching tail lights and centre garnish. you need persistence, import monster, and yahoo japan.
https://www.sau.com.au/forums/topic/291752-l28-c210-fs/#findComment-4963818
And who found the garnish?.. :P
Lights are now available for $575 firm posted to the east coast.
I'll post up the dr30 when its had some time spent on it, bit sorry looking atm but its basically rust free.
https://www.sau.com.au/forums/topic/291752-l28-c210-fs/#findComment-4969245
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
