Up for sale is my r32, been my project over the last 3 years. just need something new and different, otherwise no real reason to sell it. comes with everything you see. may be able to organise a roadworthy.
Has been by daily over that time getting me to uni, work, and all around reliably, never skipped a beat!
PRICE: $8,000 without the work eurolines and recaro's - stock rims and seats may be provided.
Engine -- 210rw kw @ 380nm of torque
___________________________________________________________
KKR 480 Turbo
Custom 3" Turbo back exhaust with twin pipes
GTR Fuel Pump
GTR Injectors
Z32 AFM
JJR coilpacks
Remap ecu (Status)
FMIC w/ 2.5" heat wrapped piping
Super Heavy Duty Clutch
Turbotech bleed valve
Blitz Sus Pod w/ Silicon Intake Pipe
GREX Oil Cooler + Relocation Kit
ASI 52mm twin core radiator
Interior
RECARO bucket seats w/ recaro rails
Blitz Boost Gauge (in Bar)
Autometer Oil Pressure / Oil Temp Gauges
Nismo Style gear knob
Nismo Short Shifter
PIVOT auto Turbo Timer
Pioneer head deck
Clarion 6" splits front
Kenwood 6" speakers rear
Brakes / Suspension / Wheels / Body work
RDA slotted front rotors
DBA slotted rear rotors
Bendix Advanced CT brake pad FRONT/REAR
Tie Rod End Spacers
4 point half cage
TEIN Front Coilovers
JIC Magic Rear Coilovers
Cusco front camber arms
JIC Magic rear adj camber arms
Front and Rear Cusco Strut bar
GTR sway bars front and rear
HICAS lock Bar
Shimmed diff
Work Eurolines
17x8+5 front with 215/40 federal 595ss tyres -- BRAND NEW tyres
17x9+20 rear with 235/40 federal 595ss tyres -- 80% tread
Ganador mirrors
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
