Well, pretty much I'm done screwing around with my v-spec ii r-tune.
I've only a few more niggles. You can see the missing center caps for one.
I need a new battery.
I'd like some coilovers that are up to Ohlins standards but are quiet.
Any recommendations?
Edited by moneypit
https://www.sau.com.au/forums/topic/291820-polished/
Damn, how long have you been hiding this R1..?
I never knew...
Nismo R-Tune R1 + HKS V-CAM, the car must really go hard.
What suspension you got in atm?
I have Cusco's atm but I must say are quite hard, but I felt Tein's are quite good.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4877532
2530s so I think it is 375 kw at 24psi but I have all the original bits so can return
to stock some time.
driving around like a granny it is smooth and quiet which makes the violence when it
boosts even more freaky.
ohlins flag-r and they feel great, not hard or bone jarring, despite having 10lb springs.
but .. they rattle on the mounts @ the rear, and I'm told that is just the way it is. Not
audible when pushing it, just when dawdling around. It bugs me.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4877554
they were installed replacing s-tune, and two different places said I'd have to live with it, Croydon was one of them.
but on another forum someone said they cut out rubber from a mat and used that in the mounts
somehow! (not flag-r but other Ohlins). Would be a shame to give them up if its just one fix away
from being done.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4878298
^^ Nice!
Built / Imported from Nismo Factory yeah..?
Have you got the rear coil overs checked out to see what the rattling noise is?
All the Nismo S1 and R1 engine builds come right out from the Omori Factory and a special build plate can be seen on the right strut tower.
I'm so jealous Justin, I've never seen an R1 engine before but plenty of S1's. I'll pm you about meetup soon and talk about my coilovers I use.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4878610
Yeah I knew that, what I was trying to ask was did Moneypit import it directly from the Nismo Omori Factory or was it bought from an Import place.
I should have explained myself ;):down:
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4879587
it is a zele car, the original owner had omori do the R1 conversion in 2003. I think if I was in Japan with a mint R34 I'd do the same. For the price you can screw up in far greater style by going to some tuning shop or another. And the car is very much still as tractable as it was stock.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4880301
I'm going to take it to tunehouse in a couple of weeks, and see what they recommend.
To get a 2nd opinion yeah..?
Ohlins are nice and IMO, no suspension should just rattle and have to live with it.
Yeah you put up with the bumpy / hard ride but noise wise, gota be checked out.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4883437
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
