Guest RedLineGTR
u would have to check for the things that make up a series 2 their have been threads about it a while ago see if u can search for it but if not i'm sure someone will write it up for you. IT might be a 1.5 series people have spoken of those and i've seen some too.. it just really depends. Cheers Rob
https://www.sau.com.au/forums/topic/29183-series-1-series-2/#findComment-598425
I think the s1.5 had a similar front bar to the s1 except it looks like a more extended version. ( comes down lower than the s1)
Series 1 front
Series 1.5 front
The series 1.5 also had the bigger spoiler of the series 2 instead of the smaller one.
S1 spoiler
S1.5 - S2
https://www.sau.com.au/forums/topic/29183-series-1-series-2/#findComment-598549
Skyline_Boy, I believe the bigger spoiler and front bar were options on 94 models and became standard on 95 models. Many people refer to the bigger front bar as a "Type M" (GTS-t, turbo model) bar because I think the GTS still came with the smaller bar as standard in 95 (not 100% sure though). But I think the bigger bar was still an option on the GTS.
MINES_DATSUN, the main differences I can think of off-hand are different ECU and different igniter/coil packs. The gearbox/diff/engine though are pretty much the same.
https://www.sau.com.au/forums/topic/29183-series-1-series-2/#findComment-599013
wtf y da hell would anyone replace a boot lock?
Probably because it had been stolen in the past and the owner didn't want it stolen again so he glued/welded it on. They cost around $175 for the titanium one.
https://www.sau.com.au/forums/topic/29183-series-1-series-2/#findComment-600703
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
