  • Replies 14.2k
wrong, this is gayer than aids
Who is that? He looks sooo dreamy... :ninja::)
Well, i know what i am going to be doing over the next few days...removing my 6000k HID kit, even though i have other things on the car i need to be more concerned about now :)
can you get caught speeding from a car camera on the opposite side of the road?
I seem to remember something about it being illigal for a camera car to flash in front of you as it could distract you or something so im going to say no you cant get caught speeding from a camera car on the other side of the road. Any one else know?
ahaha i saw the add for that story, had it aired yet? They clearly have nothing better to do if there covering the dangers of HID globes lol...
Well im going to sinergy friday could they hook me up there?? Im guessing they dont have it lying around :ninja:
You're best up taking Mitch up on his offer
there are 3 things that could be a problem
a) the horn mechanism, b) the horn itself and c) the fusing/cabling between (unlikely)
in either case the easiest thing to do is remove either the button assembly or the horn and see if that fixes the problem - its probably the horn though from the sounds of it, so take ur current one out and swap with mitch's and see if that fixes it.
otherwise, i plan on upgrading to some earthshaking horn in future cos im sick of a wimpy sounding horn so i might sell ya my 32 gtr's if ur still desperate in a couple months heh
-D
Ah cheers Ben. That clears things up :ninja: Ill send you a Pm Mitch when i have enough posts lol
I might be desperate in a few months well see how it goes
Edited by Terence-T
lol and TT said the car must have an auto washing device fitted to squirt onto the lights? wtf?
yea pritty sure they need to be able to self clean the lense.like a little wind screen wiper on the headlight so if they get dirty you can clean them so if something gets on there it wont difract the light and cause glare.
Mitch are you selling any interior bits?
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
