  • Replies 14.2k
.82 rear, thats why its a bit laggy, but u got more topend out of it
since u cant check ya knock level reading just keep an eye on ya engine warning light, if it starts to come on regulary after a boosting hard step off and getnya tuner to check everything again (timing)
I am not really fussed, still picks up speed quick, boost hits like a train...which is rather interesting, first few times i did it, it was like when they hit the NOS in Fast & The Furious :) .
Since it is more laggy now, does that mean i am going to get better fuel economy when just dribbling around town?
Not so much at 160km/h but the revs at which point on this garph it hit 160km/h if you know what I'm saying.
yeah I was only using kph as a reference for the graph....load on the road could lean it out at any speed
As a rule of thumb 14:1 at idle, and depending on your timing and amount of brake on the rollers 12:1 is the leanest I'd ever go up top.....11.5:1 is a bit safer as long as everything else is taken into consideration.......we're talking pump fuel by the way.
mate dont worry i no what its like to have a laggy turbo and thats on a forged eng. i have garrett gt3540 on mine
and like yours when boost hits it hits HARD!!!!!!!!
i love it
ahhahha my fuel economy is shit and thats rarely boosting it
I am not really fussed, still picks up speed quick, boost hits like a train...which is rather interesting, first few times i did it, it was like when they hit the NOS in Fast & The Furious :thumbsup: .
Crank up the boost to 18psi and feel the hit :)
buy decent quality straight off the bat. please. save for an extra week or 2 and buy cusco's or something.
It has been suggested on these very forums that the BC coilovers come out of the same plant as the Greddy coilovers. I'm not entirely sure whether it's true or not.... but either way the BC coilovers have springs that are too stiff for my liking!
I really do wonder, what exactly drives people to do this.
Also, why 49?
Doesnt help when your girlfriend posts what you've done over her Facebook status updates like Dan showed us!
i think krish is making similiar power to you abe. about the 250rwkw mark.
Yep making around 246.6 rwkw on 14.5psi....needing a new exhaust as when we cranked the boost up to 17psi at 400rpm it starting dropping off to 14psi and held hard on 14psi....for some stupid reason the boost wont go higher then 14psi so we ie me and the tuner came to the conclusion of needs a new cat back system and also have to get andrew from AM Performance to fit it all up as there is a leak out of the vband flange thingy
I am using a .63 rear housing so my boost comes on a bit earlier then yours Abe but has the same feeling of hitting you like a damn train when the boost kicks in.....well described with the FnF NOS scenario....cant wait to check it out tomorrow
mine is at boostworx right now, tuning the AEM FIC-8 ecu.
235kw at 5850rpm but not reving past 5850 at all - Im sure its a setting in the program,
I have made my suggestion re calibration to the tuners, so hopefully a little later I'll get the good news that all is fixed and well, reving thu to 7250rpm as per the remap chip.
the AEM FIC-8 looks great: here http://www.aempower.com/files/electronics/...lease080728.exe
for $350 off ebay its a massive score, considering the safc/sitc sold for $300 before they were even off the car! ;)
Hopefully my thoughts re the tune program setup work, and she free revs again into the red zone.
250kw
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
    • *waits* for chop idle videos and TT kit hanging off the motor. I like these sounds now, my inner bogan is growing.
    • Want to buy a good running Rb20det in Sydney preferably complete or long block
