  • Replies 14.2k
Hmmmm.. What to go with
  • 18x9.5 +12 ie TE37 or CR KAI
  • 18x10 +18 ie XD9
  • 18x10.5 +18 ie TE37, LMGT4 or CE28N
Anything less than 18x10 would look shit on a 32 GTR. XD9's look porn but a lot of people have them. What about those rims Chef had for his EVO, they looked ok.
how u get into it james?
Well stated on night shift at holdens nearly 7yrs ago, moved my way through sub assembly, then to plastics and finally landed in a Production quality assesment area. Boring as shite, but pays well. The auto industry in Australia is slowly on the demise. But getting into the civil constructioa area is pretty easy these days, plenty of jobs out there if you dont mind hard work.
  • 18x10 +18 ie XD9
I like these, not sure on how they'd look on your GTR though. Enkei GT-C 01's, pretty good light weight rim.
I want Work Meister S1's so badly. They're the wheels that will be eventually on my car.
Black center though. So hot lol
Once again a black center and maybe more dish?
If/when its time for new wheels thats what I'll be saving for.
Edited by Weezy
Oh really, LOL how embaressing - Well they're the ones I want.
S1s are 2 piece and don't have the bolts around the spokes, for future reference :)
Kinda wish I was out at the drift school today helping my mate but still not feeling well enough to drive yet :happy: will have to make do with V8 supertaxis at the Indy on TV.
Edited by AndrewJZX100
made some progress on the 31 today,
rear seats, seat belts, centre console, cd player, speakers all goneskies.
same goes for the guts of the cat and the whole tow bar.
also learnt 2 things, def need minispool, and handbrake tightened!
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
