The Sa Wasteland
heslo
 Share
  • Replies 14.2k
Just finished watching Paranormal Activity, f**k me that's a scary film. Not usually one to get a scare out of those films but this had a few moments for sure!
Was that a DVD screener? Seems weird that it was released in 2007 and my usual source for a movie only has screener versions.
Spot on, exactly the same as the theatrical release save for the alternate ending. The film actually wrapped near on 3 years ago, just a small low budget ($15000USD) but a fresh and original horror flick :blush:
Talking to a mate over the phone last night whom I haven't seen for a while and he's telling me about the R35 GTRs that he has spotted around Adelaide. :blush:
You gotta love it when your friends share in your passions even though he's never even been in a Skyline.
is any one here a metal worker?
i need/want a peice of sheet metal cut to size to cover where my rear seat used to be....
chad?
Pretty sure Chad should be able to help you out there Craig.
chad?
Give me the size's and i'll see what off cuts i've got laying around the work shop.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
