  • Replies 14.2k
Rolled guards finally, ftw.
No paint cracks or nuttin!
i did mine at the track today.
with a rubber mallet.
turned out fine.
no cracks, no warps, no deformation.
perfect.
Yeah i know, R33 making way for J31
... ugh. homo.
i lost over 5k in parts on Sunday night when someone broke into the workshop!
what got stolen
arias 40 thou pistons
spool I beam rods
apexi air filter
hks manifold
acl race bearing kits
all my gaskets including the thicker head gasket
2540 turbo
arp head studs
basically everything that was going into the build got jacked so if anyone see's some of these parts for sale give me a heads up because it'll be a bit sus when someone is selling all these parts but also the tools were stolen like all the snap on stuff! torque wrenches etc
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
