The Sa Wasteland
heslo
 Share
On another note, the 33 drove off half hour ago. Happy driving Luciano!
haha cheers
As much as i regretted getting rid of my other 33 on Sunday there, this sedan is such a great drive, I love it.
Thanks again James!
  • Replies 14.2k
haha cheers
Thanks again James!
Having a halloween mixup sat night Luke. check your FB. should be a good one :down:
Those are Security bits. Kincrome do a good little handy set, bout $30 i think. If you head down to my old work, 167-169 South Tce Wingfield, ask for Laurie and say i sent you. They will have what your after Steve :down:
No worries Luke, enjoy mate :D
It's definitely not standard allen or hex head. I use those ones all the time in my electronics projects.
It's this one...
those are secure torx , I have a driver for them
or you can find one at coventry fasteners in lonsdale
Those are Security bits. Kincrome do a good little handy set, bout $30 i think. If you head down to my old work, 167-169 South Tce Wingfield, ask for Laurie and say i sent you. They will have what your after Steve :D
Thx :thumbsup: :thumbsup:
For those who i havent told already my 26 arrived last week and tonight i decided to move it from the crate to a engine stand :thumbsup:
Gotta love when you find things on the motor that werent written in the Yahoo auctions summery, Like a nismo sports clutch with a light weight flywheel :D
Dropped some of the oil out of it tonight and it all looked sweet with no metal fillings. Took the cam covers off and they all seem fine to :thumbsup:
Random but how do you make those drawings some people have on the bottom of their profile of their car? It has the three views Front , Side , Back . Looks cool. Is there a program you use or just some really good drawer out there?
well
i may have just got myself another (better) shell to work with
anyone need an RB30 bottom end for a hi-po build? the car has a bottom end rattle, but it still runs as far as i know
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
