  • Replies 14.2k
hey craig, here's some rails that my brother modded for a customer using the factory rails and the generic slider the cheap seats come with;
Also i had one of those seats sitting in my spare room unused never fitted that you could have had for the $170 it owes me.
Edited by D_Stirls
Just washed the 34 from the track day and damm my rear guards have so many stone chips :D now to see if they polish out or need a quick brush touch.
That what you get for trying to be a rally driver at Mallala :(
I only paid 160 delivered for this one :(
cheap pos tho, but oh well, its budget.
what will your bro charge to do me one of those rails?
i also may be keen on your seat, aswell, for the passenger side.
As to not clutter up the fs thread.
Damo, just get one of these: http://cgi.ebay.com.au/Turbotech-manual-tu...#ht_1490wt_1167
http://www.skylinesaustralia.com/forums/go...ntr-t73375.html
stock 33 turbz
That one looks like what i have on my car atm.
:( Not surprised, you seemed to like off road more than tarmac that day :D
dale,
ill take the seat if craig doesnt want it!!
how far south?
i havnt got good skills, but more then happy to help (within reason :( ).
only available saturdays atm though.
if you got facebook you can see my gallery :D
Morphett Vale/Woodcroft and yes i have facebook, PM me your Email addy and i'll look it up.
who here has the mate who works at Grand Auto??
they have an RB30ET that i want moar info on NAO!!! hehe
NUGZY,
and i didn't get chance to look for that sheet metal yet, but im pretty sure i'll find something for ya.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
