The Sa Wasteland
heslo
 Share
  • Replies 14.2k
Just pull the fuel pump fuse and take the relay out as well, unplug the coil packs and they won't be able to take it. and unless they really know what they are doing they won;t know why and even if they do unless they have a relay with them they won't get it started (easily).
guess i should put that bonnet latch on and get rid of the bonnet pins then haha
LOL! did you get a chance to see the 'Weird Al Yankovic' version of that?
"they see me mowin'...my front lawn.."
har har
yeah i love wierd al's work.....he has made some of the funniest payout artist clips ever
Ah K ive only got the Slim CC plates all round, although i might have to get a square one any one know of the cost ?
$21 if youve already got them
its free if you ask for one when you first get the cc's
(just rang up ezy reg 20 mins ago to find out the ins and outs)
can someone show me how cc plates look on their skyline?
gotta get some for mine haha
have a look at my FB profile Mitch. i bought James' 33 sedan - it has CCs, fat one on rear, slim on front
whats it like parking in mt barker at night? haha
i start work up there tomorrow and im waiting on the first paycheck for full comp on the skyline
I would say depends on the night. If it's friday or satdy night (or anytime in the school holidays) I wouldn't exactly be comfortable leaving anything that looks half decent/worth something in a low-traffic area, but most week nights you shouldn't have a drama.
How long you gonna be workin in barker Mitch? I live 10 mins away so I could grab that mani off ya when you get it sorted before work or something :(
as far as i know full time , i start tomorrow so ill know what days im working up there , previously i was working tuesday and friday 1-8pm but apparently they need someone to work fulltime so im hoping monday-friday 1-8 :D
not taking the skyline up there till i get first paycheck for rego,plates,insurance & my mate to fit my alarm system as the one it is is toy and i dont trust it :)
also gotta fit my bonnet latch so no plebs mess with my engine stuff
btw Andrew , add me to msn ;D
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
