The Sa Wasteland
heslo
 Share
  • Replies 14.2k
what side of town ru on i have a crane you can borrow if ya get desprate im at munno para west
thanks man!
3 of us managed, quite easily actually to lift it out onto a stack of tyres at each end,
never under estimate teh ranga strength!! :)
i may just have to take you up on that offer when it comes time to loading it back into
the van to take it to the workshop tho... will keep in contact :P
cheers for the people who pm'ed me mitchs number, seems he likes to give it out a bit :)
<snip>
cheers for the people who pm'ed me mitchs number, seems he likes to give it out a bit :P
Not really, these days stuff like that is so accessible. Like Mitch hasnt given me his number, but I found it 20 seconds after I read your post lol.
Will be good to see your project finished. Go the 20! haha
yeah i cant wait!
the doofus also gave me, tail shaft, crossmember, full 3'' turbs back zorst with high flow cat, apexi power intake and pod heat
shield :P
hmmmm all that plus box, front mount, afm, loom, ecu etc etc for $1170, i hope there aint nothin wrong with it :)
his old man was a good bloke, so i like to think they where being 100% honest when they told me it runs like a dream.
quick question..
does anyone have any experience with having a relationship with a girl that lives say..an hour away from where they live?
does it make it harder or what?
It sucks balls man. Sure you can make it work but it still sucks balls.
*shrug*
meh, an hour or so is easy. its when they live in different states that it gets a bit iffy.
example, one of my ex's live in noarlunga, not exactly easy to find the time, but we worked it out and it last a solid 6 months til it just burned out, distance didnt have anything to do with it.
another lived in sydney. that was a head f**k. finding the time was like winning the lotto. that ended up lasting a little longer (~18 months, saw each other about a dozen times, each for a week or so), but we werent faithful. i knew it and she knew it, we just didnt talk about it.
Whos your X? i live next to noarlunga haha.
And dan why the feck someone would post that on face book is beyond me let alone why the sister just does CALL HER OR GO TO HER HOUSE to see if shes ok insted of just posting a comment on face book.
thanks man!
cheers for the people who pm'ed me mitchs number, seems he likes to give it out a bit :(
what can i say , i whore my self out
much like..... mexican hehe
-camber will win
already running -2.5 all round. i want less -camber if anything.
Pull the guard out slightly, will make it look flush. That or fit a narrower tyre, will look more agressive. Either way roll the guard and chop about 15mm out of the height.
235's all round could work. but im not lowering it more. low enough as it is. srs. exhaust scrapes and front wheels scrub as it is.
no worries, gimme a yell when you want the other 2.
and cheers for the help with the brakes... again. lol. now i just need to talk to david about borrowing his seat... :)
Edited by scandyflick
Big cheers to Dave for hooking me up with these babies today, boy are they sweet and grippy as shit to a blanket! Hope you enjoyed the spin Mr David
any ideas on where to get some of these babies, how much $$
Edited by 180or200
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
