  • Replies 14.2k
hot week next week, unfortunatly my aircon compressor bearing is siezed, any ideas on cost for repairs?
My aircon compressor clutch is fecked, been like it ever since I bought it. Got quoted roughly $450 for a s/h compressor, fitting and gassing from Jaustec.
thats who i was thinking of going through, how long ago was that quote done?
think i might go without it for a while longer then, haha.
ITS ALIVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Finally good to see Mitch...i am guessing that you haven't hooked up the stock boost gauge line either?? and as far as i know there should be a connection for the oil pressure....ahh well just get aftermarket gauge that will prob be more accurate
took my R31 to a place in lonsdale on o sulleys rd near the old ASV building who fixed the leak , new condenser and swapped out the compressor for about 300 all up including regas,top work for cheapest I could find around the south.
gotta love the ole UFC Damo......NOT for the faint hearted though (I know Carl - Bezender would agree with me)
I'd love to go toe to toe with a couple of the serial pests on these boards....may even teach them a little respect for the old fellas, lol :)
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
