The Sa Wasteland
heslo
 Share
  • Replies 14.2k
hot week next week, unfortunatly my aircon compressor bearing is siezed, any ideas on cost for repairs?
My aircon compressor clutch is fecked, been like it ever since I bought it. Got quoted roughly $450 for a s/h compressor, fitting and gassing from Jaustec.
thats who i was thinking of going through, how long ago was that quote done?
think i might go without it for a while longer then, haha.
ITS ALIVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Finally good to see Mitch...i am guessing that you haven't hooked up the stock boost gauge line either?? and as far as i know there should be a connection for the oil pressure....ahh well just get aftermarket gauge that will prob be more accurate
took my R31 to a place in lonsdale on o sulleys rd near the old ASV building who fixed the leak , new condenser and swapped out the compressor for about 300 all up including regas,top work for cheapest I could find around the south.
gotta love the ole UFC Damo......NOT for the faint hearted though (I know Carl - Bezender would agree with me)
I'd love to go toe to toe with a couple of the serial pests on these boards....may even teach them a little respect for the old fellas, lol :)
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
