The Sa Wasteland
heslo
 Share
  • Replies 14.2k
LOL, what have we started here :P ...may just have to set something up....SAU UFC Night to sort out the bluffers from the fair dinkums :D
2 codes will give you a major advantage......if you're a rare breed and have 3 under your belt, you'll be unstoppable.
Oh and Tangles, I can tee up some head gear if you're concerned and even spot you a couple of points.
I'm sure Carl (Bezender) and I could tee up something if there was enough interest......."Last Man Standing" rules, so would have to be played out over a few nights depending on interest.
hmmmm this could be very fun!!!
i weigh in at just under 100kg and 6ft tall.....
who's my perfect match? :cool:
if you say sled, get F'd, im out.
me, 5'7, 120kg
low centre of gravity yo
-D
the bigger they are the harder they fall is what my old man used to say..
sad thing is, the bigger they are, the harder it is to fkn make them fall!
lol absolutely
when in all doubt, kick them in the balls
-D
in UFC you don't necessarily need to be a technical fighter, however, most would struggle with anything more than 3 x 3 minute rounds....including myself these days, LOL.
30 seconds of high intensity is like running 1 km flat out........a hit to the solar plexes at this stage would almost see you out, so fitness (apart from some ability) is key.
It also always pays to know your opponents capabilities, ie. you don't go toe to to with a Thai expert (you try and hold him instead) and you don't go to ground against someone who knows basic holds, you won't get up again and you'll either tap out or go to sleep :cool:
im 6'2 and 106kg
time for a ranga battle!
3 x 3 min rounds would have my office job havin ass so tired it'd take me a week to recover :)
im 6'2 and 106kg
3 x 3 min rounds would have my office job havin ass so tired it'd take me a week to recover :cool:
no shit, i'd probably be knackered after round one, unless i stand still and absorb hits like one of those dudes in street fighter with a magical shield, and i do think that is an option, I just need to figure out how to levitate
-D
lol @ ranga battle, you would have to flash your pubes to prove your a ranga :cool:
3x3 min rounds would see me in cardiac arrest.
my job is pretty physical, fill about 9 pallets of stock to shelf everyday,pushing f*k off heavy flat tops and walking
a shit load... .
but surprisingly, my fitness level is disgusting!
ahahahah u are all f**ked then!!!!!!!
Craiggy Boy ill take u on!!!!!!
hes talking about martial arts, not how many red or green curries u can eat without breaking a sweat yo
-D
BTW Dean, i have decided to do the conversion myself, well, the install part anyway.
is it possible to borrow your engine crane for 2 weekends?
will throw a carton'o whatever you drink your way :cool:
i thought Ryan was doing it???
yeah thats cool it's just sitting here atm till im ready too drop the 308 into the race car
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
