sweet, we are looking at starting it next weekend, so ill be in contact to
arrange a time for me to pick it up.....
hmmmmm 308 + race car? i smell Torana?
will i need a trailer to pick it up?
what do you drink?
  • Replies 14.2k
^^ cam be done
Chad, thanks for the sheet-metal matey, nearly a perfect fit!!!!
tried to give you a call to say cheers!, realised i did have your number, under chad, not dstroy *facepalm*
Edited by craig R33
No prob's, was just some off cuts that where lying around work.
what do you drink?
you smell wrong lol its a full space frame chassis and im hoping to put a ve commy body on it
you will need a trailer make it easier
drink blondies
took the skyline out for a little bit tonight ,
runs awesome , just got a few minor things to fix on it first and it will be running how i want it
random pic/
Thats good to hear Mitch, Whose trade plate ya karnt? Handiest things EVER
was thinkin bout it, but got the biggest f off headache, and got soooo much shit to do!
thats why im goin to watch today and workin on my 31 tomorrow
the new project might not be a skidder but it'll give me a fix to inspire me :cool:
hmmmm so dale has kindly done some research on this turbs i have
sittin here...
Seems its a TD06-17c.
which will apparently be capable of 17ish psi by 3700ish rpm,.....
kinda got my juices flowing!!
not sure what to do now, VG30 or TD06?
100 bucks difference in the 2, i know the VG is in good nic as it will be comin from jeff @ speedlab....
never seen this turbs on a 20 before so makes my decision a little harder
If the TD06 can pull up 17psi by 3700rpm on a 20 I would go that personally. I was trying to minimise lag on an already laggy motor so I chose the HKS 2530 - it's the undisputed turbo of turbos for an RB20 haha.
Good luck with it, interested to see how it goes.
Edit: Never driven one, but I've heard the VG30 turbo is rather laggy on the 20.
jeff had the vg on his 31 rb20, made 220 rwkw with other mods and slid 3rd gear, so must have been half decent.....
i think ill go the TD06, curiosity killed the cat eh.....
if it turns out to be lag city, oh well, i like to learn the hard way lol
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
