The Sa Wasteland
heslo
 Share
  • Replies 14.2k
ahh ok, cheers for that, hope your right haha, rb20de+t would suck.
wonder why it would have ecr32 written on the ecu then?? hmmmm
also, changed my mind on the turbo AGAIN.
did a dummy fit, i would need to run a spacer on the flange coz the compressor housing hits the manifold
before the studs are tightened, and i need an elbow made up.
i do however need a coolant line, the one that goes from the back of the block to the back of the turbs...
anyone got one lyin round?
looms are similar, ecu's are similar
mine's a ceffy x-over pipe on a 32 engine. its a chop and change part, usually means u need the rubber elbow from the AFM with the extra bits if you want to run the factory bov
Ill drop my washing over to yours..tuesday arvo? :P
Hmm...how high does it sit?.. Like roofline height or?
its 330mm high, sits just below the roof on my car.
So are you saying Cefiro RB20's have no BPV/BOV at all? So they come with hektik flutter from the factory?
from what ive found
unless they've popped their donks in j-land and ended up with a 32 engine haha
Could look good Chad. Would definatly like to see some pics of it out on the track. Would be interesting to see how it affects your lap times also.
far out, I guess that blows the "its put there for a reason" theory
Cefiro crossover pipe here:
http://cgi.ebay.com.au/cefiro-rb20det-cros...=item3ef9e4bb5b
yeah look exactly like that.....
if it WAS factory na, it would still have to run na ecu right?
wheres dale when ya need him :P
mr hks, judging by the cars that usually have those stickers i thought that stood for Hyundai Kool Skids
u got the wrong car :P o yeah i said that
ive seen that wing b4
lol all good dude, gives it the track look. n i know how u track racers look down on us mountain passers :)
Edited by Inline 6
Hey Chad, I've got one of them in the shed too......same colour. :)
I knew you sold the 34 for an upgrade, I bet that thing handles a treat! What lap times you getting in that thing? :P
u got the wrong car :) o yeah i said that
What you on about?? I dont have any HKS stickers :P
 Share
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
