generic china spec 600x300x70 delta fin core. basically exactly the same as what i had, and it performed pretty well.
Nice. I had been looking at return flow (is that the correct term) fmic's but now I might spend the $$ elsewhere!
  • Replies 14.2k
^straight pipes into twin staggered tips!!!! ladies will throw there vagina's at you
i was thinking something along the lines of luke (heslo's) system actually. we'll see. depends how much damage is done to the exhaust, if its just the rear pipe thats mangled (centre mufflers always been a bit dented) then ill have twin 2.5" s/steel pipes with 3" resi tips thrown in behind the centre muffler.
if its completely naffed, ill probably get a kakimoto from jis.
I hear ya Dave, not racist, but ladies of african american background and ladies of the orient - do not want.
glad im not the only normal one. while i dont exclude them completely, ive made 1 exception to my rule, and that was over 12 months ago.
its funny how many people at work have yellow fever though, bugs me out a little bit.
nice and shinnyyyyyyy
Well someone was definitely happy about it.
Like this?
I did a search on Google Images for 'ladies throwing vaginas' and this page came up. Scroll down a bit for the cartoon.
african american/asian
^I'd smash that :banana: :banana: :D
Hi Mitch & Cara,
I'm David
35/mature/non-shit taker/attention avoider/(parts of) life ruined by other drivers.
Who's life have you ruined? Did it involve witchcraft or voodoo? Are you getting better at it? I think there may be a business opportunity for you, similar to a 'cooler' at casinos.
well apparantly i have ruined many lives because i have major depression
now you go telling me why you would say that to some one who has depression, yet this person says that they are here to support me and help me,...............
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
