  • Replies 14.2k
Just found out Ruby Rose is DJ'ing at one of the Sensation White Deluxe rooms on new years.
f**k yeah.
I couldn't care about what she's mixing, I just want to meet her. f**king hot as carpet muncher.
f**k yeah! Ruby Rose is mint!
That's what i was going to sell mine for
Oh well since he has one already organised i guess I'll keep mine for a little bit longer.
Just a quick heads up to anyone else that was thinking about PM me about buying my 180 for $3K. I was only kidding, hence the italics.
EDIT!!
Is it just me or has NS just disappeared?
Edited by D_Stirls
EDIT!!
how many said, "hey mate would you take $2800?"
We had a minute silence today. It was all properly done as i was in the defence force recruitment offices since 8am today.
I wanted to be a pilot, got told no. FARRRK!
so they offered me to be a marine technician on those submarines.. might do it.
NS used to be solid as a rock then about 12-18 months ago when it was down for 5 days straight it hasn't been the same. Loz' is working for PWR now so i don't think he has the time to dedicate to the site that he used to. and the new version has sucked ever since it was launched, they haven;t fixed any of the probels that have been listed on the Beta page. i know nothing about building webpages but surely it wouldn't take 12 weeks to fix the niggly little problems.
Surely the site pays the bills for him! What has become of the Project Car? Havent seen or heard of it in ages.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
