  • Replies 14.2k
All good points Pete. I myself went the Nismo route, firstly I got them cheap, second, they are direct bolt up, no mods required and I don't like molesting looms and third, if you're really sneaky you can go through regency with them on. Z32's; no chance
Couldnt you disguise the Z32? The exterior dimensions look very similar to the RB2x ones, so if I took both AFM's to an electrical place couldnt they put in the z32 innards into the RB2x one - I know the Z32 has one more pin, but Im assuming its not required when fitting to an RB. Then as an absolute max I would only have to change the order of wires going to the AFM..
Im just thinking...
Also, can you get nismo ones for the RB20/25?
does anyone want to put a cd player in for me tomorrow or today even?
would like someone down south ways but im not too picky!
HELP ME! i havent had beats for over 6 months yo!
Its like 800degrees man I don't think so lol,
I would but you live heaps far away and yeah too hot.
What car out of interest?
not even, its only about 700degrees
only ranga's need fear the heat
my f**king drift car has a cd player but my daily doesnt, thats messed up lol
Where abouts are you and what car?
im in morphett vale but ill come to you or you come to mine i dont mind either way, plus ill pay of course
its a s1 33 4door
Edited by Import S13
lol its not that hot
I was at my mechanics for some time last night and this morning fixing his dyno dynamics dyno
Got it up and running a couple hours ago. We tested it on a nearby ute, it made a staggering 75kw ;P
Sure its warm today but its not hot... wait till its 45'c, then you can say its hot heh
-D
-D
yea last year i was working on a customers car in there garage on the 3 days we had that was over 45, didnt know someone could sweat that much haha
Slightly warm out, been working on the car since 10am, perhaps just distracted and not noticing it :D
Also caught the top of my foot on the corner of the passengers seat rail while getting out of the back, massive gash and a trip to the doctors :P
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
