  • Replies 14.2k
Yeh, which Ben built from the ground up with the help of my bro, and other mates. I was there most of the time lending a hand where possible.
Miss those days
the car looked a million times better when ben had it then now that its just a un-cared for drift hack
when he asked me to help a couple times i didnt want to touch it, it was just so perfect lol
pics of my old shitter and what amazing looks like lol VVV
i seem to get a fair bit of bubbling noises outa my car when i switch it off in this weather.
tripple checked the coolent levels after it cooled down and they seem ok, temp gauge seems pretty happy to while driving :) strange cars
Mine actually wants to stall sometimes when I get off the throttle, it only does it sometimes and that's only ever when the AC is on!!!
any one wanna add to my work van fixing fund?
Problem #1... put diesel in it when i picked it up, didnt start, had to wait half hour for it to ''cool down''
Problem #2...smashed the rear window on my gate when i opened the door
Problem #3... scratched the Mc'fek outta the insulation on the side walls while loading in the crane.
Problem #4... dented the refridgeration unit with said engine crane.
Problem #5...leaked about 3 litres of engine oil all over teh inside floor.
wasted 9 bucks with the high pressure hose trying to squirt it out, sorta succeeded.
oh and dont forget the speeding fine i got on the way home, 67 in a 60 me thinks :P
I REALLY HOPE YOU APPRECIATE THAT CHEAP RB20 WITH ''FREE'' DELIVERY ANDREW!!!!!
Off to nissan tomorrow to get prices on the following. Hope i get change from 1500.
• Timing Belt
• Water pump
• NSK timing belt idler bearing
• Tensioner Bearing spring
• 2x Cam seal
• 1x Front crank seal
• NSK timing belt tensioner bearing
• Thermostat
• Fuel Filter
• O2 sensor Part numbers? Front and rear
• 5x Exhaust manifold studs
• Cam cover seal
• Throttle body + Plenum gaskets
• Front diff housing gasket?
• Oil filter block gasket
• Rear crank seal
• Coil pack loom
• Alternator + Power steering belts
• 12x exhaust manifold washers
• 12x exhaust manifold nuts
• 4x turbo to manifold locking tabs
• 1x copper crush washer kit
• 1x oil drain to block gasket
• 2x oil drain gasket.
anyone want to donate to my winch fund?
im sick of pushing busted cars onto my trailer............they're fecking heavy LOL
i'd be happy to help you out at some point, but not sure how much i'd have till the cars back on the raod =\
Timing Belt $80~
• Water pump
2x Cam seal $44~ ea
• Thermostat
• Fuel Filter
• Cam cover seal
• Rear crank seal
• Coil pack loom
Alternator + Power steering belts $30ea~
• 12x exhaust manifold nuts << they are m 1.25 thread , just go to an auto shop and get a pack of tensile ones , way cheaper
hope thats some help , thats some of the stuff i bought for mine :)
haha
should ask more people to break down :)
eh, i'll put off a small spend on the 31 f*kit
appreciate it david, cant have these girls getting the wrong idea
I'm here to help. Your previous statement was going to create extremely high expectations that mere mortal men wouldn't be able to live up to. And that just creates disappointment. Now the ladies expectations have been lowed to the point where all you could possibly do is exceed them.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
