Bringing one over from Japan, along with a 25DET gearbox (thats costing more than the engine :huh: )
bring over more than one gearbox maybe, drop the costs
:D
i'll buy one haha
and pete, that woulda been ideal mate.......pity that you miss out again
  • Replies 14.2k
indeed good spot, guess i bashed that 1 in a lil too fast before heading off. me fail English that’s umpossible post-31501-1258982731.jpg
who authorised you with a grammer police badge :)
i failed yr 12 twice :) was told i should pick a different career as I wasnt "smart enough" to be an accountant. i never liked being told what to do and I had a all or nothing approach so i did it anyway :P
Edited by Inline 6
already got a job, been working for about 4yrs. was doing the uni thing part time at night. which does wonders for your social life i assure you.
now to ask for a pay rise :)
Edited by Inline 6
lol, im a part time grammar police...kinda like your Army reserve.
I admire your resilience, you did what you had to do and it payed off ten-fold.
You now drive a GTR, just finished Uni, and can ask for a pay rise.
Awesome work.
Go see Rob And Rocco at Synergy, they get Tru-flo pumps fro japan, basically an N1 copy for a fraction of the price. Put one on my old 33 just before i sold it.
Well actually someone that works at Sinergy will probably be doing it for me. One of Waynes mates.
well, the 31 has yet another heart..
found one on NS.com, from a guy in salisbury who owns his own detailing shop.
ended up getting it complete, without turbs for 8 hunge. sweet.
pick it up thurs arvo, chuck it in sat, drop dales crane off sunday = win (fingers, dick'n balls crossed) x
i'll grab those mounts for ya before thurs matey :thumbsup:
oooo.. went and did about 4 hours worth of work on my car today!!! =D going back in to do some more tomorrow!! soo happy, might even have the car on saturday, if not tuesday with any luck!!!
but found this... the cause of all my pain ratteling round in the oil cooler... =(
one on the left is $2, one on the right is $20k+ =\
what is it? loose oil restrictor plug or a bearing of some sort? bit blurry
-D
I've posted this in the cosmetic section as well, but I thought I might try my luck here as well.
I'm looking into buying an R34 that is in good condition except for the wind deflector, which has a crack in it. Are these hard to remove? What's the process of removing them?
Thanks in advance.
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
