  • Replies 14.2k
Or I can get super discount at Lakeside if you ask me nicely
dear Luke,
Im writing to you NICELY, in hope you may be able to help me with
your trade discount at Lakeside Nissan.
I am in need of:
12x Exhaust manifold stud
1x exhaust/turbo Gasket Kit
4x turbo stud
1x bomb (preferably afghan made) to blow this bitch up.
thank you.
sincerely
Craig Smith.
the new 20 come with a flywheel, which is in better nic than the one i have...
only thing is it has some very light surface rusty lookin stuff on it,
will i need to clean it off? with what??
if i was to sell a car interstate without the guy coming to look at it, how do i transfer rego to him as he wont be able to sign the paperwork?
i'm guessing i need to do it on the rego site or something? i'd just like to have a desposal notice to hand in as soon as it's gone.
Research tells me that i should just leave it and run it, the clutch will rub it off....
i have so much f*king work to do.
just sign your part of the disposal notice and leave it in the glovebox. he will have to transfer the rego from his end.
yeah good idea Damo.
Not only will the buyer get it, but the truck driver, the people that load/unload it, and whoever gets there
greasy little hands on the car....
idea of the century, three gold stars for you.
haha its an SR man, you could put fuel in the engine and oil in the petrol tank and it would still smash the limiter happily.
not quite. sr's have a bit of a love/hate thing with rev limiters.
its the rb20's that you can do that do and still live on limiter without harming it.
lol, i want the disposal notice.
so incase he never changes the rego to his name in the other state it cant be linked back to me for any stupid shit that he might get cought for.
there would have to be away to do it online but im wanting the notice with his signiture onit.
hoping someone on here might have done it.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
