  • Replies 14.2k
Or I can get super discount at Lakeside if you ask me nicely
dear Luke,
Im writing to you NICELY, in hope you may be able to help me with
your trade discount at Lakeside Nissan.
I am in need of:
12x Exhaust manifold stud
1x exhaust/turbo Gasket Kit
4x turbo stud
1x bomb (preferably afghan made) to blow this bitch up.
thank you.
sincerely
Craig Smith.
the new 20 come with a flywheel, which is in better nic than the one i have...
only thing is it has some very light surface rusty lookin stuff on it,
will i need to clean it off? with what??
if i was to sell a car interstate without the guy coming to look at it, how do i transfer rego to him as he wont be able to sign the paperwork?
i'm guessing i need to do it on the rego site or something? i'd just like to have a desposal notice to hand in as soon as it's gone.
Research tells me that i should just leave it and run it, the clutch will rub it off....
i have so much f*king work to do.
just sign your part of the disposal notice and leave it in the glovebox. he will have to transfer the rego from his end.
yeah good idea Damo.
Not only will the buyer get it, but the truck driver, the people that load/unload it, and whoever gets there
greasy little hands on the car....
idea of the century, three gold stars for you.
haha its an SR man, you could put fuel in the engine and oil in the petrol tank and it would still smash the limiter happily.
not quite. sr's have a bit of a love/hate thing with rev limiters.
its the rb20's that you can do that do and still live on limiter without harming it.
lol, i want the disposal notice.
so incase he never changes the rego to his name in the other state it cant be linked back to me for any stupid shit that he might get cought for.
there would have to be away to do it online but im wanting the notice with his signiture onit.
hoping someone on here might have done it.
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
