Hmmm. Well in the process of my alarm installation we've found my car used to have a boost controller, turbo timer and some sort of temp gauge. Also my standard boost restrictor has been removed.
Now with that removed and a catback exhaust my installer seems to think I'd be running atleast 14psi and he says I'm risking detonation because my timing or something might not be right and that I should hook up a boost gauge to know exactly how much psi I'm running and he can make it so I don't run the risk of detonation.
Is he talking shit or should I be concerned?
I found a turbo timer when I had my alarm installed. Was all hooked up, working... just was tucked under the dash in the footwell. You find crazy shit under there.
I thought without the restrictor, it runs at 12psi?
Mine still has the restrictor, so I have no idea.
  • Replies 14.2k
Man knows his stuff. Boost gauge is invaluable, esp when you simply don't know all the variables (ie condition and internal construction of turbo, afr's with the current tune, etc etc).
I still got a tonne of shit wiring above my drivers side footwell, thats after removing the old security system and turbo timer and replacing it with a decent ADR compliant one. Loads of bad japanese engineering (read: bits of wire twisted together and taped with racing tape) as well as wires leading from my spotlight button to the thermofan (i didnt realize japan got so hot they needed a thermostat override, meh)...
Another job for me to do next time I find a compelling reason to pull my dashboard off
-D
Dion, if u read this. Was just looking at the engine u brought, you do know u have to pay aus customs, quarantine, agent fee's, docking fee's, storage fee's on that engine when it arrives here? roughly another 800-1k on top of the buy it price which streeter has quoted u.
Lol same. kicked mine by accident and saw a blue flash, then the car wouldnt turn off lol.
I lived in Japan for a stint many years ago. On the Kyushu island, mainly in Takanabe, and it got hot there in summer. Weather was almost identical to Adelaide's ... so I wouldn't be surprised.
:bunny:
ouch.... i hope he did realise this, he seemed to think it was a fair cheap engine :bunny:
sooooooo.....
who wants to give me a hand sunday, need to bolt the engine and gearbox in??
got captain thread comin out tomoz morning to get the 3 broken studs out, quoted $110.
ill put the motor in minus turbs as ill need to grab new gaskets/studs etc and wont have time before sunday....
theres Beer in it for ya.......
please.......
BJ inc
sooooooo.....
please.......
BJ inc
sheeeet, just remembered i hadnt grabbed them engine mounts yet.
tell ya what, i'll grab em tomorrow and either send them your way with one of the boys, or sat nite im heading to redwood park so can drop them off to ya
i just bought a grands worth of shockies for my race car from the states and didnt have too pay any extra tax on them customs had opened the boxes and re taped them shut
I've had quite a few items sent over from overseas worth more than $1K+ and have never had to pay tax on it, yet I have heard of so many that have had to.
Anyone here know spark plugs?
What are these telling me about how my cars running?
Also some new clamps :bunny:
The ends seem to be the right colour, so it tells you it is running right. If you saw plugs that i took out of my car a few weeks ago you would have seen it was running wrong, which now reminds me i need to check the condition of the new plugs.
haha no worries mate.
yeah im planning on dropping the motor in on sunday, as Dale's bro in law needs the crane back, for
a long time by the sounds of it, poor bugger...
yeah if you cant grab them let me know, as ill be down south tomorrow and could possibly grab them??
i got an idea, how bout you bring them to me sunday and give me a hand?? :bunny:
yer mitch, ill be there.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
